NeenerIII
Aug 03, 2021Aspirant
Google Nest Wifi Router will no longer communicate with CM1000v2 Modem
Everyone working from home, kids at, etc, upgraded my network to a Google Nest Mesh (one Nest router as the router, two Nest routers connected as access points). My Modem is a CM1000v2 and I have Co...
Aug 03, 2021Guru - Experienced User
Try powering OFF both CM modem and the wifi router for 1 minute then back ON.
Ensure the cable between the modem and router is of good quality. CAT6 is recommended.
If the router won't connect to the modem and your direct connected PC does, then this is a issue with the router, not the modem.
NeenerIII
Thanks for the reply. I have tried the long reset over the phone with Google support, not luck.
I do have some interesting info now. I reconnected a Netgear router that I had used before the Nest. It seemed to be in a similar situation. No internet from the modem. I set the Router to use my PCs MAC address and now I have internet from both WIFI and hard wired to the Router.
Not sure how to mimic this on the Nest.
- FURRYe38Aug 03, 2021Guru - Experienced User
Something to contact Google/NEST support about regarding there product.
