NeenerIII
Aug 03, 2021Aspirant
Google Nest Wifi Router will no longer communicate with CM1000v2 Modem
Everyone working from home, kids at, etc, upgraded my network to a Google Nest Mesh (one Nest router as the router, two Nest routers connected as access points). My Modem is a CM1000v2 and I have Co...
NeenerIII
Thanks for the reply. I have tried the long reset over the phone with Google support, not luck.
I do have some interesting info now. I reconnected a Netgear router that I had used before the Nest. It seemed to be in a similar situation. No internet from the modem. I set the Router to use my PCs MAC address and now I have internet from both WIFI and hard wired to the Router.
Not sure how to mimic this on the Nest.
Aug 03, 2021Guru - Experienced User
Something to contact Google/NEST support about regarding there product.
