Philsaywas
Apr 30, 2019Aspirant
GS308P-100UKS replacement PSU
does anyone know how to get hold of a replacement PSU for a GS308P-100UKS POE switch
additude
Apr 30, 2019Virtuoso
I think these switches have a lifetime warranty.
Request an RMA via NetGear.
Login otr create a NetGear account if you haven't already.
Then proceed accordingly.
- PhilsaywasApr 30, 2019Aspirant
the PSU is water damaged due to its old location, now in a weather proof box
- additudeApr 30, 2019Virtuoso
I Googled it and came up with several options.
But you would need something for the UK, right?
Any power supply that meets or exceeds the voltage and current requirements and has the same size barrel plug will work as a substitute.
Power requirements should be Stamped/Molded/Stickered close to the connector jack.
It looks like the barrel plug is the 5.2mm size....
What I found were conflicting output voltages so I can't say it's 5v, 12v or 48v .....
Sorry that I couldn't help further....
