Fish0fWater
Oct 11, 2016Aspirant
GUI doesn't load properly on C3700
Hi all, for the last few weeks I have been trying everything I can think of to get my modem to work right. When I try to log in I can't get the GUI to load so I can make the changes I need. I took a ...
Fish0fWater
Oct 22, 2016Aspirant
Fish0fWater wrote:Hi all, for the last few weeks I have been trying everything I can think of to get my modem to work right. When I try to log in I can't get the GUI to load so I can make the changes I need. I took a screen shot for you to see and here it is.
If you know how to fix this it'd be great...
Note, This is only the case on my Windows 10 PC.
Forgot to mention that tid bit... ISP is Comcast as I know different firmware version #'s are for different ISP's
- DarrenMOct 24, 2016Sr. NETGEAR Moderator
Hello Fish0fwater
I would suggest contacting netgear support about this if you believe its the modem and not something with the windows 10 pc.
http://www.netgear.com/support/contact.aspx
DarrenM
