midian5214
Feb 26, 2022Aspirant
Hard wired internet, no wifi for devices
Hello, My internet was going in and out last night due to snow storm. My internet was restored, and my C7000v2 router is hard wired to my desk top, but all of my wifi receiving devices say, "Interne...
- Feb 26, 2022
Try a factory reset with the modem disconnected from the ISP coax cable line.
Connect 1 wired PC to the back of the modem and press the reset button for 10 seconds then release.Can you access the modems web page at 192.168.0.1 or 192.168.1.1 in a web browser?
If you see the start up setup wizard here, walk thru the setup wizard and complete the wizard. Set a simple short named WiFi SSID and give a simple wifi password for now. When you get to the home screen see if any of your devices sees the SSID name.
If you can't see the new SSID name or connect with any wifi devices, possible the wifi radios went bad.
Let us know if you get this far.
Feb 26, 2022Guru - Experienced User
Be sure the wifi radio LED button the modem is enabled. Press it for 5 seconds then release.
Try a factory reset and setup from scratch?
midian5214
Hello again,
Furrye38, I did the factory reset and still no wifi at devices, ie: TV, XBox, etc. Put in network name & pw, and no internet... I also tried to start setup from scratch, in which the "routerlogin" or "IP address" comes back to Netgear, and the "Router login page cannot be dispayed" is shown. ...and you have to be connected to your router wifi network... I can't get to the Admin page as diricted in dirrections, but you can download an APP from Google Play, in which I can't because I have no wifi access w/ my devices, except for my hardwired desktop.?. My head is going around in circles....
- FURRYe38Feb 26, 2022Guru - Experienced User
- midian5214Feb 26, 2022Aspirant
Hey FURRYe38,
Before you sent me your last mesage, all the wifi devices do see the SSID Name, and acknowledge the C7000 Router. But, the access to the internet is still a no go, even with trying the coax disconected... The Only wifi device that does work/get internet is my old laptop.?. Go figure... You've been helpfull, and if you have any other idea remedies, please don't hesitate to post it for me... Still not fixed...
Thank You,
midian5214
- FURRYe38Feb 27, 2022Guru - Experienced User
Something you can try, if you can get to the modems web page:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
You might want to contact NG support if you can and see what RMA options are availalbe to you:
Hey FURRYe38,
I forgot to mention, that when I put the IP address(192.168.0.1) in the browser, it comes to Netgear web page, but No install wizard... If you have any more ideas, please let me know.
Thanks again,
midian5214
