llacroix4683's avatar
llacroix4683
Have internet but no WIFI (model C3700)
Reset the Netgear C3700 router and have internet (using cable) but no WIFI. Tried to login to the router using https://routerlogin.net but can't login. So ran IPCONFIG and tried to login to the gatew...
  • FURRYe38's avatar
    Im thinking the router portion of the modem is in some bad state that we can't get it out of.
    Last idea to try...look up on how to do a 30-30-30 reset.
    If this fails then the modem needs to be replaced.
