llacroix4683
Dec 13, 2022Aspirant
Have internet but no WIFI (model C3700)
Reset the Netgear C3700 router and have internet (using cable) but no WIFI. Tried to login to the router using https://routerlogin.net but can't login. So ran IPCONFIG and tried to login to the gatew...
- Dec 13, 2022
Im thinking the router portion of the modem is in some bad state that we can't get it out of.
Last idea to try...look up on how to do a 30-30-30 reset.
If this fails then the modem needs to be replaced.
llacroix4683
WIFI radio is on and the 2.4G and 5G lights are on. Can't seem to login to router using Edge or Chrome, says it is insecure site.
Dec 13, 2022Guru - Experienced User
Disconnect the ISP coax cable from the modem. Factory reset by pressing the reset button for 10 seconds then release. Use a ethernet connected PC with the modem and Try MS Edge or Firefox and navigate to 192.168.0.1 or 192.168.1.1. See if you can access the setup wizard and complete it. If you can, then reconnect the ISP coax cable to the modem...
