llacroix4683
Dec 13, 2022Aspirant
Have internet but no WIFI (model C3700)
Reset the Netgear C3700 router and have internet (using cable) but no WIFI. Tried to login to the router using https://routerlogin.net but can't login. So ran IPCONFIG and tried to login to the gatew...
- Dec 13, 2022
Im thinking the router portion of the modem is in some bad state that we can't get it out of.
Last idea to try...look up on how to do a 30-30-30 reset.
If this fails then the modem needs to be replaced.
Dec 13, 2022Guru - Experienced User
Try a factory reset by pressing the reset button for 10 seconds then release. Use a ethernet connected PC with the modem and Try MS Edge or Firefox and navigate to 192.168.0.1 or 192.168.1.1. See if you can access the setup wizard and complete it.
llacroix4683
I tried login to router using Firefox (had tried Edge and Chrome) and it brings me to a Netgear Geni page to change my password, when I do that and click the 'next' button, nothing happens.
- FURRYe38Dec 13, 2022Guru - Experienced User
Be sure to clear out all browser caches and any browser saved password profiles for the modem. Try try accessing the modems web page. Be sure you press the reset button for 10 seconds and that you feel a momentary bump when you press the reset button. Try pressing it for 15 seconds as well.
- llacroix4683Dec 13, 2022Aspirant
Thanks for all the help but still can't get to the setup wizard. I used IP address 192.168.0.1, also I disconnected the ISP cable but still not working. I clipped a picture of the web page and attached to this reply. Maybe you'll see something I'm doing wrong.
