llacroix4683
Dec 13, 2022Aspirant
Have internet but no WIFI (model C3700)
Reset the Netgear C3700 router and have internet (using cable) but no WIFI. Tried to login to the router using https://routerlogin.net but can't login. So ran IPCONFIG and tried to login to the gatew...
- Dec 13, 2022
Im thinking the router portion of the modem is in some bad state that we can't get it out of.
Last idea to try...look up on how to do a 30-30-30 reset.
If this fails then the modem needs to be replaced.
llacroix4683
WIFI radio is on and the 2.4G and 5G lights are on. Can't seem to login to router using Edge or Chrome, says it is insecure site.
Kitsap
Dec 13, 2022Master
llacroix4683 wrote:WIFI radio is on and the 2.4G and 5G lights are on. Can't seem to login to router using Edge or Chrome, says it is insecure site.
It is not a "site". It is a web page on the router on your local area network.
Accept the advanced exception and connect anyway.
Are you using the IP addresses FURRYe38 recommended?
