llacroix4683
Dec 13, 2022Aspirant
Have internet but no WIFI (model C3700)
Reset the Netgear C3700 router and have internet (using cable) but no WIFI. Tried to login to the router using https://routerlogin.net but can't login. So ran IPCONFIG and tried to login to the gatew...
- Dec 13, 2022
Im thinking the router portion of the modem is in some bad state that we can't get it out of.
Last idea to try...look up on how to do a 30-30-30 reset.
If this fails then the modem needs to be replaced.
llacroix4683
Thanks for all the help but still can't get to the setup wizard. I used IP address 192.168.0.1, also I disconnected the ISP cable but still not working. I clipped a picture of the web page and attached to this reply. Maybe you'll see something I'm doing wrong.
Dec 13, 2022Guru - Experienced User
- llacroix4683Dec 14, 2022Aspirant
The 30-30-30 reset worked!!!!!
Thanks
- FURRYe38Dec 14, 2022Guru - Experienced User
Kewl.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
