rareaagle
Aug 19, 2018Aspirant
have to reset modem a lot
Have to reset modem a lot. Modem problem or ISP problem?
rareaagle
Unplug power, wait couple minutes, and plug it back it. This will correct problem (no internet)
michaelkenward
Aug 19, 2018Guru - Experienced User
Sorry, but another question, when you say "no internet", do you mean that the wifi goes off, or stuff wired to the router?
What do the lights on the thing look like when this happens?
There is support for the CM400 at the end of this link:
>>> CM400 | Product | Support | NETGEAR<<<
Check the section Use LEDs to Troubleshoot.
