Homeuser66
Feb 04, 2020Guide
Have to unplug C7100V constantly.
I have had this modem now for a little over 2 years. I haven't had an issue until now. Just recently, like with in a month or so, I have ben losing my wifi connections. (Not sure of the ethernet conn...
vkdelta
Feb 05, 2020NETGEAR Employee Retired
Please provide power values screenshot as well.
it looks like line has an issue.
Please confirm cable and connectors are ok.
Please check another connector in the house.
- Homeuser66Feb 05, 2020GuideWhere do I find this power data?
- vkdeltaFeb 06, 2020NETGEAR Employee Retired
in the main page, there should be an an icon called Cable connection. Once you click it, you will lot of values in a table format. Take screenshots and put it on imgur and let us know the links.
- Homeuser66Feb 07, 2020Guide
Hope this helps?
Netgear C7100V Cable Connection Info.
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure</tabindex=-1>
Procedure Status Comment Acquire Downstream Channel 555000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Configuration File OK ------------ Security Enable BPI+ <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 17 555000000 Hz -4.6 dBmV 39.7 dB 891 0 2 Locked QAM256 18 561000000 Hz -4.6 dBmV 39.3 dB 1156 0 3 Locked QAM256 19 567000000 Hz -4.6 dBmV 39.6 dB 1537 0 4 Locked QAM256 20 573000000 Hz -4.9 dBmV 39.5 dB 1903 0 5 Locked QAM256 21 579000000 Hz -4.9 dBmV 39.6 dB 1912 0 6 Locked QAM256 22 585000000 Hz -5.1 dBmV 39.4 dB 2701 0 7 Locked QAM256 23 591000000 Hz -5.3 dBmV 39.2 dB 4952 0 8 Locked QAM256 24 597000000 Hz -5.6 dBmV 39.1 dB 7058 0 9 Locked QAM256 25 603000000 Hz -6.1 dBmV 38.9 dB 9676 0 10 Locked QAM256 26 609000000 Hz -6.3 dBmV 38.8 dB 10450 0 11 Locked QAM256 27 615000000 Hz -6.8 dBmV 38.4 dB 14987 0 12 Locked QAM256 28 621000000 Hz -7.1 dBmV 38.4 dB 20099 0 13 Locked QAM256 29 627000000 Hz -7.2 dBmV 38.0 dB 25505 0 14 Locked QAM256 30 633000000 Hz -7.5 dBmV 37.9 dB 37240 0 15 Locked QAM256 31 639000000 Hz -7.4 dBmV 38.0 dB 32428 0 16 Locked QAM256 32 645000000 Hz -7.6 dBmV 37.9 dB 42582 0 17 Locked QAM256 33 651000000 Hz -8.0 dBmV 36.8 dB 0 0 18 Locked QAM256 34 657000000 Hz -8.3 dBmV 36.6 dB 2 0 19 Locked QAM256 35 663000000 Hz -8.6 dBmV 36.2 dB 1 0 20 Locked QAM256 36 669000000 Hz -8.5 dBmV 36.2 dB 0 0 21 Locked QAM256 37 675000000 Hz -8.6 dBmV 36.1 dB 0 0 22 Locked QAM256 38 681000000 Hz -8.6 dBmV 36.1 dB 0 0 23 Locked QAM256 39 687000000 Hz -8.6 dBmV 36.2 dB 0 0 24 Locked QAM256 40 693000000 Hz -8.6 dBmV 36.3 dB 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 4 5120 Ksym/sec 17300000 Hz 45.3 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 36500000 Hz 45.5 dBmV 3 Locked ATDMA 2 5120 Ksym/sec 30100000 Hz 45.5 dBmV 4 Locked ATDMA 3 5120 Ksym/sec 23700000 Hz 45.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Current System Time: Fri Feb 07 08:27:34 2020System Up Time: 74:39:06
