Quick44
Jan 12, 2021Aspirant
Having a lot of issues with internet since switching to CM1100
So basically we had a 100mb down/30up connection and we decided to upgrade it to a gigabit connection and we had to upgrade both our modem and router. We got the CM1100 and the nighthawk x6S r7900p. ...
Jan 12, 2021Guru - Experienced User
For that up speed wonder why you have channel 5 locked in. I have 50Mb on the Up and only get 4 channels locked in.
Still, your ISP needs to take a closer look at your service line and signals up to the modem.
Quick44
Jan 13, 2021Aspirant
So I got in contact with my ISP and they said that the signal up to the modem is good and that the provisioning was set up correctly. Anything else I can do?
- FURRYe38Jan 13, 2021Guru - Experienced User
Try a different modem and see if the problem continues or not.
- Quick44Jan 13, 2021Aspirant
So basically whenever that lag happens with no ping spikes or packet loss this is what shows up in my router logs. Is that an actual DDOS attack?
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:11:48
[admin login] from source 192.168.1.6, Thursday, Jan 14,2021 05:11:37
[admin login failure] from source 192.168.1.6, Thursday, Jan 14,2021 05:11:33
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:11:18
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:10:48
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:10:18
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:09:48
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:09:18
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:08:48
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:08:18
[DoS attack: Fraggle Attack] from source 10.64.128.1,port 67 Thursday, Jan 14,2021 05:07:48 - FURRYe38Jan 14, 2021Guru - Experienced User
So a whois look up on that address.
Is this with your wifi router connected?
- Quick44Jan 14, 2021Aspirant
I looked up other solutions and that is just a false positive. What I did that seemed to fix it so far was change my DNS server from the ISP one to cloudflare. So far so good!
- Quick44Mar 02, 2021Aspirant
Still having the same issue as before with high variance in ping in online games. When I do ping in the cmd I get around 20-30ms for gooogle while every 10-20sec there is a packet that takes over 150ms and sometimes over 300ms.
