Quick44
Jan 13, 2021Aspirant
Having a lot of issues with internet since switching to CM1100
So basically we had a 100mb down/30up connection and we decided to upgrade it to a gigabit connection and we had to upgrade both our modem and router. We got the CM1100 and the nighthawk x6S r7900p. ...
Jan 14, 2021Guru - Experienced User
So a whois look up on that address.
Is this with your wifi router connected?
Quick44
Jan 14, 2021Aspirant
I looked up other solutions and that is just a false positive. What I did that seemed to fix it so far was change my DNS server from the ISP one to cloudflare. So far so good!
- Quick44Mar 03, 2021Aspirant
Still having the same issue as before with high variance in ping in online games. When I do ping in the cmd I get around 20-30ms for gooogle while every 10-20sec there is a packet that takes over 150ms and sometimes over 300ms.
