Homeboy123456
Feb 18, 2020Aspirant
Having DNS connection issues on my guest Network - CG3000D
Hello, I have set up a guest network on my Netgear cable modem. The guest network is having trouble with DNS servers. Some sites work fine: gmail, google, wikipedia. Some sites give this error...
Feb 19, 2020Guru - Experienced User
the CG3000D was a modem that was directly sold to ISP's such as cox/spectrum.
https://kb.netgear.com/24324/No-NETGEAR-support-for-the-CG3000D
I couldn't find much info on it or its newer version the CG3000D supporting a guest mode either. Potentially you could try factory resetting it but I doubt your isp is going to do much for support on it if it doesn't work.
Homeboy123456
Feb 19, 2020Aspirant
plemans wrote:I doubt your isp is going to do much for support on it if it doesn't work.
Yup, that's exactly what happened. To the extent that they said they didn't work on 3rd party modems. I told them they provided me the modem!
And yes, I read the manual for similar CG3000s, and there's NOTHING in there about guest networks. And yet, I created one via the Cox website; and I can discover it using my phone or computer.
- plemansFeb 19, 2020Guru - Experienced User
I would probably factory reset it to disable the guest network.
I'm not a huge fan of guest networks. Those I trust on my network can use the full network, those who i don't, can use their phone date.
Just what I've done on mine. No complaints yet
