MissLini
May 19, 2016Follower
Having issues with connectivity on Destiny
I have a Netgear C6300, with the firmware V1.02.20 and I keep getting booted out of Destiny with the error code 'Weasel'. Which apparently is a network issue.
My ISP came out and said that everything on their end was fine. And Destiny's support forum absolutely sucks so I am here to see if anyone has any idea where I can boost the signal to my xbox one so maybe I don't get booted so often. I know that some websites say do a QoS but I can't seem to find any area on this router for that.
I have UPnP enabled, I am port forwarded, I have a 300 mbps internet connection.
Oh, also, I have been trying to get my ISP to upgrade my firmware to 1.02.21 4 times now and they haven't done it. They say they schedule it but nothing happens. Can I go around them another way to upgrade it?
Thanks much for any info
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello MissLini
Do you have Time Warner cable if so they just certified the new firmware and it should be pushed to your modem in the next couple weeks which should fix some issues.
DarrenM
