tomter
Mar 22, 2018Aspirant
HELP! C7000 Router no longer blocks any porn! Parental setting not working. I don’t know what to do.
I have a Netgear C7000 cable/WiFi modem with cable service from Spectrum. I setup the Parental Controls via the Netgear Genie app. I had it set at the Moderate level. It worked perfectly about 3 mont...
Mar 22, 2018Guru - Experienced User
You should post this here since you have a cable modem:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
