Asianflavor
Jul 08, 2019Guide
Help c7800 router
Having a problem with my c7800 the main problem is that now my internet will just shut off randomly. I've never had this problem and I think it's my isp but I just wanted to make sure I didn't get a d...
Jul 10, 2019Guru - Experienced User
Look for Modem logs. You'll T3 and T4 information in the logs.
I don't have CC ISP.
You might contact CC and have them check the logs from there end as well.
Asianflavor
Jul 11, 2019Guide
So yesterday we had an outage here not sure why and there was a cc truck outside my apartment fixing thing and the whole day it was pretty stable but the problem is when I woke up this morning it was down again I really hope it's not my modem maybe I should use it only as a modem and try that? Also I found event logs and then just logs and I didn't see anything that told me t3 or t4 so I'm not sure...maybe I'll just screenshot them all?
- FURRYe38Jul 11, 2019Guru - Experienced User
Sounds like an ISP issue to me if they were out doing something.
Can try tne modem in modem only mode and connect up a external router and see.
Have the ISP check the logs from the modem as well when these events happen.
- AsianflavorJul 11, 2019GuideWell they were out to fix the outage in my neighborhood because we had a bad thunderstorm here and I guess it knocked something out but yeah all good points and I thank you for your time hopefully it will get fixed soon seems better now though
- FURRYe38Jul 12, 2019Guru - Experienced User
Enjoy. :smileywink:
