Asianflavor
Jul 08, 2019Guide
Help c7800 router
Having a problem with my c7800 the main problem is that now my internet will just shut off randomly. I've never had this problem and I think it's my isp but I just wanted to make sure I didn't get a d...
Asianflavor
Jul 11, 2019Guide
So yesterday we had an outage here not sure why and there was a cc truck outside my apartment fixing thing and the whole day it was pretty stable but the problem is when I woke up this morning it was down again I really hope it's not my modem maybe I should use it only as a modem and try that? Also I found event logs and then just logs and I didn't see anything that told me t3 or t4 so I'm not sure...maybe I'll just screenshot them all?
Jul 11, 2019Guru - Experienced User
Sounds like an ISP issue to me if they were out doing something.
Can try tne modem in modem only mode and connect up a external router and see.
Have the ISP check the logs from the modem as well when these events happen.
- AsianflavorJul 11, 2019GuideWell they were out to fix the outage in my neighborhood because we had a bad thunderstorm here and I guess it knocked something out but yeah all good points and I thank you for your time hopefully it will get fixed soon seems better now though
- FURRYe38Jul 12, 2019Guru - Experienced User
Enjoy. :smileywink:
