Ganesh8383's avatar
Ganesh8383
Follower
Nov 05, 2015
Help needed on N300 Wifi Modem Router C3000 - Internet connection
All of a sudden, my internet stopped working. The device is displayed in all my wireless device and it is getting connected to my laptop, phone & tab. But, internet is not working. All the lights are glowing except the top one, which is a small button kind of. I tried calling COX and they said everything looks good from their side. They said I have to check with Netgear as there may be router issue. I did resetting, and basic troubleshooting, but none worked. Can some one help me please
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Ganesh8383
    How are you trying to connect via wifi or Ethernet? and what operating system are you using?
    DarrenM
  • Same thing happened to me! Netgear said I'd have to spend $79 to fix it
    • DarrenM's avatar
      DarrenM
      Hello Saramc
      Is all the lights still on but you have no internet connection?
      DarrenM
