InkytheGhost
Jan 16, 2021Aspirant
Help needed please CM1200 slowdown
Charter Spectrum Internet Ultra 400 Mbps was running a CM500 that had my internet running above the 400 Mbps Modem: Nighthawk CM1200 Version: V2.02.05 Ethernet Port Aggregation Status: Inact...
Jan 16, 2021Guru - Experienced User
What speed do you get with a pc/laptop directly connected to the modem?
Your results were indicating you were going through the router. And the router could be the issue and not the modem.
Especially since you're speeds directly off the linksys were hitting full speeds.
And you power levels look good on the modem (you didn't include the logs)
InkytheGhost
Fri Jan 15 21:22:01 2021 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:21:56 2021 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:21:56 2021 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:21:56 2021 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:21:56 2021 Error (4) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:21:56 2021 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv4
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:17:36 2021 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:17:31 2021 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:17:31 2021 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:17:31 2021 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:17:31 2021 Error (4) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 15 21:17:31 2021 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 14 21:25:59 2021 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Tue Jan 12 19:43:30 2021 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
Tue Jan 12 19:42:52 2021 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=08:36:c9:a4:0a:c8;CMTS-MAC=00:01:5c:66:c6:61;CM-QOS=1.1;CM-VER=3.1;
- plemansJan 17, 2021Guru - Experienced User
A screen snip is easeir to read when it comes to logs.
- InkytheGhostJan 17, 2021Aspirant
it wouldn't let me post a screengrab and everytime I even tried to post that above I had to post and repost 6 times to even get it to stay on the forum. I don't have an ethernet port for my laptop.
- FURRYe38Jan 17, 2021Guru - Experienced User
You can copy and past from the modem web page like mine is:
