Strikersfan
Oct 23, 2020Tutor
Help Please! CM1200 Downstream Light Blinking
Been surfing through the forum posts, and seen some isues similar to mine, so I'm hoping someone can point me at a solution. My CM1200 downstream light blinks continuously, and I randomly drop my con...
Strikersfan
Oct 23, 2020Tutor
Does anyone know why my imported images of my modem screens aren't showing?
antinode
Oct 23, 2020Guru
> showing?
In-line images must be approved by a moderator before others can see
them. The time required varies. Attachments have no such limitation.
Of course, attachments have their own one-per-message limitation.
- StrikersfanOct 24, 2020Tutor
Thanks for the tip on the images. I used the photo button in the post, but that doesn't seem to have worked. I am trying now to just copy and paste the images in but that isn't working either. Trying to add just one again below, if it doesn't become visible, can anyone advise with specific instruction as to how to insert an image into my post please? Thanks everyone. It's been a super frustrating week with my connection and I'm trying every avenue possible to fix it....
- plemansOct 24, 2020Guru - Experienced User
to attach them, click on "choose file" under this text box when doing a reply.
Thank you! Sorry for my newbness, trying via the attach file button now....
