gdwwdg
Feb 24, 2021Guide
help please cm1200
i have multiple ip address xfinity does offer multiple ips without bussniss line my other modem was a aris 8200 with two ethernet ports i was able to use both ports seperate ip address i upgraded or...
Mar 01, 2021Guru - Experienced User
So if you are using WAN port #1 for one router device, to get the next router or device to connect fully to WAN port #2 of the CM modem, one should connect the device to the #2 port, then reboot the CM modem from the modems web page. Ensure LAG is disabled on the CM1200. WAN #1 and #2 should have different WAN IP addresses. Mine does. If you connect a 3rd and 4th device to WAN port #3 then #4, you would do the same process again as above.
The XR700 needs a SFP adapter to use on it's 10Gg port correctly:
"10 Gigabit SFP+ PORT—Connect to NETGEAR SX10 gaming switch
for lower latency wired gaming, or use for up to 10Gig Internet
connectivity. Requires compatible SFP+ module or DAC (not included)"
I would use the 1Gb WAN port since the CM1200 modem only supports 1Gb rates only. You'll not gain anything with using the 10Gb SFP port with the CM1200 modem.
gdwwdg wrote:i have multiple ip address xfinity does offer multiple ips without bussniss line my other modem was a aris 8200 with two ethernet ports i was able to use both ports seperate ip address i upgraded or at least thought i did to the cm1200 from net get and even with multible ip addresses it still will only connect 1 at a time. very odd because aris 8200 with two ports works giving two different ip address but netgear cm1200 wont. please dont respond saying i need another ip address i bought a pack of 4 xtra i pay for each month and aris worked just fine giving 2 different public ips, cm1200 wont
gdwwdg
Mar 04, 2021Guide
thank you it works. i also used your advise on how to connect to xr700 thank you again for your effort and time
FURRYe38 wrote:So if you are using WAN port #1 for one router device, to get the next router or device to connect fully to WAN port #2 of the CM modem, one should connect the device to the #2 port, then reboot the CM modem from the modems web page. Ensure LAG is disabled on the CM1200. WAN #1 and #2 should have different WAN IP addresses. Mine does. If you connect a 3rd and 4th device to WAN port #3 then #4, you would do the same process again as above.
- FURRYe38Mar 04, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
