aaronedmiston
Oct 30, 2016Aspirant
Help Updating Firmware to V2.01.14
I have a C6300 modem router combo on firmware V1.02.20, and recently found our that V2.01.14 is available. I have tried contacting Mediacom to push the update to my modem router as I had seen was nec...
DarrenM
Nov 01, 2016Sr. NETGEAR Moderator
Hello aaronedmiston
The Firmware is different on every ISP and Netgear can not upgrade the firmware on cable modems it is all pushed out by the ISP even if its a customer owned modem.
DarrenM
- aaronedmistonNov 01, 2016Aspirant
If that is the case, then Netgear needs to update the Current firmware version for NETGEAR cable modem routers page to reflect that. According to that page, all ISPs should be on V2.01.14 for the C6300.
