JORBI
Jun 26, 2022Follower
Help using nighthawk cax80 with orbi rbr850 and 2 satellites
Not sure if there are detailed steps in another post, but i'm doing something wrong. Started by downloading the orbi app. Went through the steps, but mobile device wouldn't connect to "orbi 50" add...
Jun 26, 2022Guru - Experienced User
First, do you have the CAX80 up and running/working?
What I'd recommend then is to run the orbi in access point mode.
Just make sure to have the orbi on a different wirless channel and with a different ssid than the CAX.
That prevents interference.
It allows you to still use the CAX's wifi but have the coverage of the orbi.
