curtissleeth75
Aug 10, 2015Follower
Help With Firmware Unbricking!
my wndr 3300 is bricked i think, i upgraded my firmware on it and then the wifi went off and its pwer button just blinks help.
DarrenM
Aug 12, 2015Sr. NETGEAR Moderator
Hello Curtissleeth
Are you able to log into the router at all and see the GUI? If not try and do a factory reset on the back of the modem with a pen and then see if the power button stops flashing then try to log back into the router. hope to hear your feedback
DarrenM
- DarrenMAug 12, 2015Sr. NETGEAR Moderator
Here is also a article i found about reinstalling the firmware if you cant get into the gui
DarrenM
