srh2110
Sep 22, 2019Aspirant
HELP/ADVICE De-bugging Attacks on Nighthawk AC1900 (Showing Logs)
Hi - I have unusual bandwidth activity on my Comcast account (over 1TB this month when normal monthly usage is 300GB) and so I have been spending hours trying to both troubleshoot devices as well...
srh2110
Sep 23, 2019Aspirant
Thanks FURRYe38 for your reply. What I meant is that in my Netgear Genie UI the "Disable" radio button is unchecked, which I assume means (with the double negative) that it is in fact, enabled? (image attached)
Thanks for your other suggestions. I will try that.
Sep 23, 2019Guru - Experienced User
Yes, you are correct.
