CJ_M
Jul 27, 2021Aspirant
Hissing sound
My router was silent for 6 months but now has a hissing sound with wi-fi. (It also drops the ISP, but that is probably a separate issue) Google reveals: "...when you have a 'hissing' it's usuall...
CJ_M
Aug 31, 2021Aspirant
I give up on Netgear. What a time-suck this has been.
And I'm out $350 on a 8 month old unit.
Customer Service did what I wrote below.
Thanks to those in the community who offered help.
I did everything I should, but still lost.
Moving on.
- FURRYe38Aug 31, 2021Guru - Experienced User
I'll ask about getting a review on this for you.
In mean time, do you have a different modem or a spare router on hand? You can continue to use the modem portion of the C7800 with the wifi disabled and connect up a different wifi router system. Couple of options would be to use the modem in router mode with the radios disabled and conenct up a different wifi router in AP mode to provide wifi signals or configure the modem for modem only mode and connect up a external wifi router to the modem and run this configuration.
Hopefully someone from NG can figure something out for you.
