apol's avatar
apol
Home cable LAN connect only on netgear-guest
Hi, all PC of my home cable LAN doesn't connect to Netgear14 but only to Netgear-guest.
Laptop connect to both on wireless net. Is this a setup problem of modem or of the norton security firewall configuration?
  • Hello apol
    Have you tried to change the SSID of the router or the security type?
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello apol
    DarrenM
