RemyMM
Feb 04, 2022Tutor
horrible modem router and support
spent FOUR hours trying to connect. ISP says it is connected but Nighthawk won't connect to FOUR separate devices and TWO different browsers due to privacy issues. GARBAGE. india support is absolu...
Feb 04, 2022Guru - Experienced User
You didn't give us much to go off.
1. what router do you have?
2. is there a seperate modem (based off your title)?
3. what firmware is on the router ?
4. what actual error are you getting? A screen snip of it can help
5. what method of setup are you using? setting it up with an app? Using the browser?
Details are key since we're not there to see whats going on.
- RemyMMFeb 04, 2022Tutor
This is under NIGHTHAWK... it is a netgear nighthawk modem. AX2700 DOCSIS 3.1 WiFi Cable Modem Router (CAX30)
I get this error with Edge, Chrome, on my desktop, android phone, tablet...
Your connection isn't private
Attackers might be trying to steal your information from www.costco.com (for example, passwords, messages, or credit cards).
NET::ERR_CERT_AUTHORITY_INVALIDYour connection isn't private
Attackers might be trying to steal your information from www.amazon.com (for example, passwords, messages, or credit cards).
