skyjockey
Jun 22, 2023Aspirant
Horrible wifi wi-fi speeds with C7100V, 2G 36Up 34Dwn: 5G 154Up 38Dwn
Are there any settings I can play with to get better wifi (wi-fi) speeds? Current Speed Test done sitting next to the device from my iPhone11 is 2g band 36 up and 34 down, on 5G band 154 up and 38...
michaelkenward
Jun 22, 2023Guru - Experienced User
skyjockey wrote:
Previously I was renting a device from Comcast that could get the gig speeds and I got as high as 608 up and 33 down.
Unlikely on wifi, especially on a device from 2019.
Do not confuse connection speed with traffic speed.
Wifi speeds depend on the wifi clients. Very few, if any, will get that upload speed.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
- schumakuJun 22, 2023Guru - Experienced User
Double check the "Mode" configured on the 2.4 and the 5 GHz band. Don't be confused - these are not the naked wireless speeds you can achieve. Much more this does set the max bandwidth of the two bands.
Are you located in a place where many more wireless networks are active on-air concurrently? Agee with michaelkenward - duckware has a brilliant overview and insight information on WiFi options. Yes, the 802.11ac tech is aging as we talk - technically, the C7100V is a wireless device from the last decade.
Probably, changing (especially the 5 GHz channel) could help. Curious: What channels does the device offer to you?
