skyjockey
Jun 22, 2023Aspirant
Horrible wifi wi-fi speeds with C7100V, 2G 36Up 34Dwn: 5G 154Up 38Dwn
Are there any settings I can play with to get better wifi (wi-fi) speeds? Current Speed Test done sitting next to the device from my iPhone11 is 2g band 36 up and 34 down, on 5G band 154 up and 38...
Jun 23, 2023Guru - Experienced User
what wired speeds do you get?
the 5ghz should be faster than that but a lot depends on what you're incoming signal is like so its worth checking wired speeds before even testing wireless speeds.
