Mitchk25
Jan 29, 2017Follower
Horrible Xbox/PS4 Speeds
Okay so I live in Dallas, TX and I use TWC for my ISP and get their 300 Mbps down 25 Mbps up service and on Speedtest.com it is saying that I get this. But on my Xbox (Hardwired to my NETGEAR Nigh...
DarrenM
Feb 01, 2017Sr. NETGEAR Moderator
Hello Mitchk25
I would check your cable make sure that is not a issue you may also want to check the behavior by testing it on the wifi see if the same thing happens.
DarrenM
