Piupolino
Aug 03, 2021Guide
How bad can customer support be?
I am mismerized by how bad Netgear cusotmer support is. My cable model is defective and they don't wan't to replace. So I had to call Xfinity to, together with the Netgear support, go over the case. ...
Aug 04, 2021Guru - Experienced User
Support cases are not discussed here in the forums. I recommend you reach out to a forum moderator so they can help you further.
Thank you.
