Piupolino
Aug 03, 2021Guide
How bad can customer support be?
I am mismerized by how bad Netgear cusotmer support is. My cable model is defective and they don't wan't to replace. So I had to call Xfinity to, together with the Netgear support, go over the case. ...
Aug 04, 2021Guru - Experienced User
Support cases are not discussed here in the forums. I recommend you reach out to a forum moderator so they can help you further.
Thank you.
vkdelta
Aug 05, 2021NETGEAR Employee Retired
I am not from support team but if you can provide details about the issue, we can help.
- PiupolinoAug 05, 2021Guide
Thank you! Together with a support agent, we concluded my Cable Modem needs to be replaced. It is under warranty and bought directly via the Netgear store. However, the agent never sent me the details for the replacement (although he promised to do that). When I call support again, they want to go over the troubleshooting and the 3 hours that I spent with the first agent, all over again. The ticket number with that agent is 44866608.
- FURRYe38Aug 05, 2021Guru - Experienced User
I recommened you send Christian_R a PM regarding this as well.
Piupolino wrote:Thank you! Together with a support agent, we concluded my Cable Modem needs to be replaced. It is under warranty and bought directly via the Netgear store. However, the agent never sent me the details for the replacement (although he promised to do that). When I call support again, they want to go over the troubleshooting and the 3 hours that I spent with the first agent, all over again. The ticket number with that agent is 44866608.
