RDougShelton
Jan 21, 2024Initiate
How can I assign bandwidth to Lan ports on my CM1200?
I have two network cables coming out of my CM1200. One goes to my LinkSys network router, and the second goes directly into my LG TV. The LG TV also has a downloadable network speed tester. Now, I...
Jan 21, 2024Guru - Experienced User
Something that the CM modem does not support since it's a modem only and the ports on the back of the CM modem are ISP WAN IP addressable ports only. If your ISP supports this then you could possibly have up to 4 different WAN IP addresses thru the modem.
- RDougSheltonJan 24, 2024Initiate
I figured that I'd strike out on my query. However - can anyone tell me why I'm getting only 100Mbps when my ISP service is one Gbps and my Cable Modem is *hard-wired* to my LG TV? I don't get it.
- FURRYe38Jan 24, 2024Guru - Experienced User
How are you determining your only getting 100Mpbs? This seen on the TV?
Is there a wifi router connected behind the CM modem?
Have you tested a wired PC connected directly to the back of the CM modem to check speeds?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
