RDougShelton
Jan 21, 2024Initiate
How can I assign bandwidth to Lan ports on my CM1200?
I have two network cables coming out of my CM1200. One goes to my LinkSys network router, and the second goes directly into my LG TV. The LG TV also has a downloadable network speed tester. Now, I...
RDougShelton
Jan 24, 2024Initiate
I figured that I'd strike out on my query. However - can anyone tell me why I'm getting only 100Mbps when my ISP service is one Gbps and my Cable Modem is *hard-wired* to my LG TV? I don't get it.
Jan 24, 2024Guru - Experienced User
How are you determining your only getting 100Mpbs? This seen on the TV?
Is there a wifi router connected behind the CM modem?
Have you tested a wired PC connected directly to the back of the CM modem to check speeds?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
