tommynei
Jun 07, 2020Follower
How can I connect HP Laptop directly to CM400
I'm trying to test the speed coming out of the modem because XFinity is suppose to be giving me 275mbps and I'm only getting 120-135 tops! A couple of times I was only getting 35mbps, and upload was ...
Jun 08, 2020Guru - Experienced User
Make sure your laptops networking settings are set to auto obtain IP addressing for the wired adapter in the laptop. Remove any static IP address configurations.
tommynei wrote:I'm trying to test the speed coming out of the modem because XFinity is suppose to be giving me 275mbps and I'm only getting 120-135 tops! A couple of times I was only getting 35mbps, and upload was rediculous! I have a new HP laptop, new CM400 modem, and a 3 year old R6400 router. I followed the steps on Netgears help section, pluged in the ethernet cable, opened the browser, put in http://192.168.100.1 and nothing was found. I'm not a cumputer guru but I kinda know my way around. Does anybody have any light to shed?
- antinodeJun 08, 2020Guru
> address configurations.Unless that's exactly what you need to do.
> [...] Get the User Manual. Look for "Troubleshoot" and "Cannot Log In
> to the Cable Modem".Still my advice.
