strykerzr350
Jun 13, 2019Guide
How do I access the CM700 spectrum analyzer?
As the title states, I would like to access the spectrum analyzer for the Netgear CM700. If anyone knows the correct port I would like it.
- Jun 21, 2019
I don't think the cm700 supports a spectrum analyzer as it uses the puma chipset and not broadcom chipset. I could be wrong though.
strykerzr350
Jul 02, 2019Guide
Thanks apparently its a Broadcom feature only, I am marking this as solved.
Jul 02, 2019Guru - Experienced User
Yes you would be correct.
strykerzr350 wrote:Thanks apparently its a Broadcom feature only, I am marking this as solved.
