1 Reply
  • > I'm using this: [...]
       While you were there, did you fetch the C7100V User Manual?
    > I can't seem to find the option to change my IP address. [...]
       What, exactly, does "my IP address" mean to you, and why, exactly, do
    you want to change it?
       Presumably, you, personally, do not have an IP address.  Your C7100V
    cable-TV modem+router has two IP addresses: LAN, and WAN/Internet.
    Which one is your "my IP address"?
       The LAN settings should appear in the C7100V management web site at
    ADVANCED > Setup > LAN Setup.  The WAN/Internet settings should appear
    at ADVANCED > Setup > Internet, but the typical arangement for these
    involves "Get Dynamically from ISP", which means that your ISP, not you,
    determines your WAN/Internet IP address.  In some cases, disconnecting
    your C7100V from your ISP might give you a new WAN/Internet IP address
    when the connection is reestablished, but that still depends on how your
    ISP arranges such things.
    > [...] I was able to consistently change my IP [...]
       How, exactly?
    > [...] with my previous Netgear router, [...]
       Not a very detailed description of anything.
