GiGito2
Jun 11, 2024Aspirant
How do I change Nighthawk Ac1900 password
How do I change the password on my cable modem router? My next-door neighbor is using a jammer on my wireless security cameras and when they do it jams my Wi-Fi
michaelkenward
Jun 11, 2024Guru - Experienced User
What cable modem router?
AC1900 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
If you mean the wifi password, manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
- GiGito2Jun 11, 2024Aspirant
C7000v2
