GiGito2
Jun 11, 2024Aspirant
How do I change Nighthawk Ac1900 password
How do I change the password on my cable modem router? My next-door neighbor is using a jammer on my wireless security cameras and when they do it jams my Wi-Fi
Jun 11, 2024Guru - Experienced User
If you're 100% sure he's using a jammer, you can report him. Its illegal under the FCC
michaelkenward
I had my suspicions. Brings us back to the first message.
What problem does GiGito2 see?
Start with that rather than an interpretation of the possible cause and fixes.
