GiGito2
Jun 11, 2024Aspirant
How do I change Nighthawk Ac1900 password
How do I change the password on my cable modem router? My next-door neighbor is using a jammer on my wireless security cameras and when they do it jams my Wi-Fi
Jun 11, 2024Guru - Experienced User
One thing you can do and I would recommend, get you some ethernet connected security cameras, if you feel there is some interferences, you should resolve that by switching to some wired cameras. Much harder to interfere with.
Might get into a Wi-Fi router system that you can also change the Wi-Fi Power levels to something lower, giving you a smaller foot print in coverage and limiting interferences from external signal sources.
You could still use the C series gateway and configure it to a modem mode, then get something that has some power adjustments for the Wi-Fi.
GiGito2
I have been in this house for over 20 years, but the times and the neighborhood have both changed. Also reading about WPA for greater security. I like the real time viewing of my wireless cameras and that there are no subscription fees, but may need to go to wired cameras. Thank you for your advice.
- FURRYe38Jun 11, 2024Guru - Experienced User
Wire would have same features and access to real time viewing.
Good luck.
