Laura999999
Feb 15, 2021Aspirant
How do I do a factory reset of N300 WiFi Cable Modem Router
My wifi is horrible and I'm trying to change the channel but I cannot login because the admin login and password are not working so now I need to do a factory reset but there is no factory reset butt...
- Feb 15, 2021
It does have a reset button. There's a picture in the manual on page 101. Its on the bottom of the device. There's a little round hole versus the rest are rectangular. Push and hold it for 7-15 seconds while your device is powered on.
DarrenM
Feb 17, 2021Sr. NETGEAR Moderator
You may want to check with your ISP to make sure something didn't change on your account that is giving you a slower Internet speed.
DarrenM
Laura999999
Feb 17, 2021Aspirant
Thanks! I should clarify that I did already speak with the ISP, they show nothing wrong on their end (and the wifi works with a cable). I also did a factory reset of the modem/router and still no improvement in wifi connectivity/speed.
