Tucumanian
Aug 31, 2020Follower
How do I enable DHCP ON my nighthawk CM1100
Hi there. I am trying to hook up my router to my teradici zero client from work and the DHCP os failing. I also had to manually set the WiFi router manually bc of this issue. Where do I go to enable this feature on my router? Thanks in advance!
-Gastón
-Gastón
1 Reply
The cm1100 isn't a router. It doesn't have any dhcp or routing functions. Its strictly a modem.
You need a router after the modem and that'd control dhcp.
