izzyh
Mar 17, 2019Follower
How do I turnoff my old WiFi network?
I had to reset my c7110v modem. I how have the old name on my computer under wifi and the new name. How do I delete the old one?
1 Reply
> I had to reset my c7110v modem. [...]
If you say so. The C7110V is a modem+router, not simply a "modem".
> [...] I how have the old name on my computer under wifi and the new
> name. [...]The key phrase there is "on my computer". Whatever your "my
computer" is, that's where you'd need to delete it.> [...] How do I delete the old one?
Why not set the name back to what it was before you reset the C7110V?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.
