mchandler
Mar 23, 2020Aspirant
How do I upgrade the router firmware on R6400 without the app
Hello, My router just stopped working. It's only 3 months old. Last time this happened, it just needed a firmware update but we had to a complete factory reboot. I cannot update the firmware using th...
mchandler
Nevermind. I figured it out. For others trying to figure that out, here are the instructions:
1. connect your computer to your router with an ethernet cable
2. go to "routerlogin.net"
3. type "admin" for the username and the password you set up for admin
4. click Advanced>Administration>Router Update>Check
- FURRYe38Mar 23, 2020Guru - Experienced User
Mark your thread as solved so others will know.
Also review user manuals. This shows you how to update FW as well.
Enjoy.
