StarboardBow
Jul 07, 2017Star
how is correct local system time set?
Have C3700-100NAS, currently running firmware V2.02.08 upgraded thru Comcast xFinity ISP. In troubleshooting still open issue with the embedded web interface failing after about week uptime (see ...
StarboardBow
Jul 16, 2017Star
As noted in initial post, feedback from Comcast xfinity ISP tech support indicated that incorrect local time on modem is not issue with their internet service feed.
As shown in modem Advanced->Administration->Logs, after reboot of modem, modem logs [Time synchronized with ToD server] event but corresponding timestamp of logged event is one hour behind correct local time (see attached screenshot of log)
Also as shown in modem Advanced->Administration->Event log, after same reboot of modem, modem logs Critical (3) priority event "SYNC timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing..." (see attached screenshot of log)
Could incorrect modem time issue be related to possible firmware flaw not properly recognizing proper local timezone daylight savings?
- DarrenMJul 19, 2017Sr. NETGEAR Moderator
Hello Starbound
As vkdelta said this is coming from the ISP but there servers do not use Daylight savings to avoid having issues with time mismatches.
DarrenM
