michelle9818
Apr 14, 2020Aspirant
How long do modem routers last
Hello - I am wondering how long a typical Modem/Router lasts. I currently have the N600 WiFi Cable Modem Router C3700 model that I bought almost 6 years ago. It is working fine but I will be moving t...
Apr 15, 2020Guru - Experienced User
Basically a lot depends on your cable service.
Reason I say that is you can always turn the C3700 into a modem only and disable its router features. Then you can add a better router or mesh system to cover your home for better coverage speed.
Plus so if the C3700 meets the speeds you're paying for, it should work since you can always add a router to it for better coverage.
Plus I'd recommend a modem seperate from a router anyway. It allows you to control the firmware on the router and if one device goes bad, you're not having to replace a more expensive unit. a little more on the buy in to have to buy a modem and a router.
michelle9818
Apr 15, 2020Aspirant
Great to know, thank you for the help, I appreciate it!
