Masterpiece17
Feb 26, 2025Aspirant
How many devices can you put in the MAC filtering table on a CAX30
How many devices can you put in the MAC filtering table on a CAX30? I use MAC Filtering for all wireless devices but not wired so need to know how many devices I can MAC filter to allow them access....
Masterpiece17
Jun 12, 2025Aspirant
Thanks. I ended up buying the CAX80 and am having an issue where my internet speed goes up and down. So from 400mb down to 30mb down, then back up. This is a continous issue and happens on wired or wireless device. It is brand new has has the latest firmware. I have turned a bunch of stuff off in it and nothing I have done has solved the issue. This happens in minutes not hours and I have not been able to pinpoint it. Concerned as I only have 30 days to return if bad or just inherant to this model. Any help would be appreciated. I check with ISP to see if there was something on their side. This has been going for almost a week. Since I first put it online last Saturday.
- FURRYe38Jun 12, 2025Guru - Experienced User
Which ISP are you with?
This happening on both wired and wireless devices?
How is the CAX80s wireless configured?
Channels being used?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerWhat FW version is on the CAX80 router and modem sides?
